Aod transmission to a c4 transmission
Just w was wondering if any body knows any articles or information on doing this conversion from an aod to a c4
does the AOD converter..flex plate. .crossmemeber...driveshaft. .interchangeable??
what all will I need to do tomake this conversion work
Any info would be nice. .just wondering what I can an cant use from my aod I have now because im goin with a built c4 with manual valve body an a transbrake. .would be nice if I could use my previous converter drivershaft etc
Flex plate will work if you run a 164 tooth bell and the big pattern converter. the crossmember will work with some light mods. Dont know about the shifter I always went with a A/M one. Drive shaft will work also from a T5 car never did the aod to c4 swap but it should
