95 GT VERT STOPS RUNNING - MustangForums.com
Old 01-05-2014, 09:31 PM   #1
EGULL
Default 95 GT VERT STOPS RUNNING
OK here's the deal. Started the car went to the store (all is good) left the store and the car stopped running. (onlya10 minute trip or less) Car wouldn't start after that. Went back today and the car started ran for 10-15 minutes and same problem. (wouldn't start) Any ideas? I have changed plugs & fuel filter. Cranks over finejust won't start after driving it for awhile.
I THOUFGT FUEL PUMP BUT I CAN HEAR THE FUEL PUMP COME ON WHEN I TURN THE IGNITION ON.
HELP PLEASE!!! AS I'MINST. LOUIS WITH A MAJOR SNOW STORM!!!!!
THANKS IN ADVANCE FOR YOUR HELP
EGULL is offline   Reply With Quote
Old 01-05-2014, 10:13 PM   #2
Ineedmorespeed
After Driving it for awhile and when it wont start back up - do you have Fuel and Spark?
I had a similar issue and it ended being the ignition control module..
Ineedmorespeed is offline   Reply With Quote
Old 01-05-2014, 10:17 PM   #3
Nstaley
Check your battery connection? Sometimes those can get loose when hitting bumps and possibly shut off the car. Go to any advanced auto or Autozone and have your battery tested and your alternator. But I might be wrong because it does crank over. My friend also had this problem and he fixed it with two possible solutions. 1. he reset his computer and two he got a new starter.
Nstaley is offline   Reply With Quote
Old 01-06-2014, 02:19 PM   #4
mongolchuck
Definitely sounds like an ignition issue. The TFI module was moved to the fender in 1994 to help with the heat soak problems from when it was mounted to the distributor. They are still susceptible to problems on the fender as well so start there.
mongolchuck is offline   Reply With Quote
Old 01-11-2014, 05:15 PM   #5
EGULL
What is the TSI
Old 01-11-2014, 05:20 PM   #6
EGULL
Thanks for all the replies but it's still doing the same thing. Put a new fuel pump in. So it has spark & fuel. Checked battery connection. Starts but won't continue to run- Pulled codes said 121or 122 TPS LOW VOLTAGE Could the TPS cause this?
Old 01-12-2014, 07:51 AM   #7
dawson1112
Ok so the car runs for about 10 min then shuts off and wont restart until it sets for bit?
TFI ( thick film ignition ) or other wise fords fancy name for ignition module ...
located on the passanger side fender under the air box. How ever these stopped being much of a problem in 94 with the sn95 body compared to the fox platforms that have the tfi mounted to the distributor. The reason for relocation was these modules are highly susceptible to heat , once they start going bad they get hot and cause severe popping and bucking along with stalling, once cooled off they run normal again. However when one of these goes bad , you generally get no spark at all until it cools.
If you are getting spark, I would check to see if your spark is a good blue/white spark indicating a strong hot spark, or is it a reddish/orange spark indicating weak spark. A failing coil when it gets hot will produce spark, but it will not be a strong enough spark to maintain ignition , or start. Once the coil cools it may start up for a period of time until it gets hot and the resistance becomes to great and it fails.
dawson1112 is offline   Reply With Quote
Old 01-15-2014, 07:32 PM   #8
EGULL
Talking
OK Here's the latest:
New fuel pump, New TPS
Started up ran for 10 seconds and died.
Has Spark from coil.
Put a screw driver in the end of the spark lug and cranked the engine but couldn't see spark!!! from the wires (checked 2 different ones)
Also did I check spark correctly?
OH IS THERE A BALLAS WIRE ON THIS MODEL? SORRY IF I SPELLED THAT WRONG
Any ideas as what to do!!!! HELP PLEASE
Old 01-17-2014, 08:52 AM   #9
aode08
Replace this module TFI=THICK FILM INTEGRATED, and the coil pack.
$60, the ford distributor tool to remove it is like $4 at autozone.
aode08 is offline   Reply With Quote
Old 01-24-2014, 05:59 PM   #10
EGULL
Question
Here's the latest update:
New TFI,COIL, CAP, ROTOR, FUEL FILTER & PUMP, & TPS
I CAN'T GET ANY SPARK!!!
how does the TFI get electric? is it fom the PIP sensor?
no spark at wires naturally since there is none at the coil!!!
HELP PLEASE WHAT ELSE COULD IT BE? I GUESS THE DIZZY
Switching from 3.89 to 3.00 gears... musnicki Classic Mustang General Discussion 8 09-23-2015 07:11 AM
01 Mustang Overheating :( MusicCity615 General Tech 7 09-12-2015 07:05 AM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 09:43 PM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 07:30 PM
2007 TR3650 which GM Syncromesh fluid IronRaptor GT S197 General Discussion 1 09-09-2015 08:10 AM
