1993 Convertible Door Stuck
Old 01-08-2014, 07:30 PM
KingKai
KingKai's Avatar
Default 1993 Convertible Door Stuck
Hey y'all, I am in a very big pickle with my Fox body.
Yesterday we had a very cold snap here in GA and when I went out to start my car the door opened fine, which is rare on cold days. As I went to shut the door my troubles started, my drivers side door refused to latch closed. After a few good slams I gave up but later in the day, after it warmed a bit, it closed.
Now today I ventured out and I cannot get my drivers side door to open at all. Ive tried both the inside and outside door handles to no avail. I managed to get the door panel off with the door closed and everything is attached but I cannot get the latch to give even pulling on the pins.
Thinking it was the standard actuator issue I pried it loose and removed it but the lock and latch still will not budge.
Im basically at a loss as to what has happened and what to do next. I don't mind replacing parts but I obviously need the door open to do so.
If anyone has had a similar issue Im begging you, please help. Any suggestions are welcomed.
KingKai is offline
Old 01-11-2014, 05:22 PM
TOOT
TOOT's Avatar
I couldn't get either of the doors open Tuesday when here in Philadelphia it was 12 degrees. I read some where (can't remember where) to spray white lithium grease in the key hole and latch area.
Never had to mess with the actuator.
TOOT is offline
foxdude
09-24-2015 08:45 PM
rafotree
09-22-2015 03:55 PM
Ipaman
09-22-2015 07:01 AM
mustangchef
09-04-2015 08:08 PM
Quick Reply: 1993 Convertible Door Stuck
