My New 1990 Mustang GT, Lots of questions - Page 4 - MustangForums.com
Old 01-29-2014, 04:14 AM   #31
Ballistics
Ballistics's Avatar
Looking to order the HCI combo sometime today. I'm going to meet someone today to make a possible purchase of a trick flow intake with a 70mm throttle body for really cheap. The guy doesn't know what kind of trick flow intake it is, so hopefully it's a track heat because he said he knew it was for up to 6500 rpms
Ballistics is offline   Reply With Quote
Old 01-29-2014, 10:48 PM   #32
aode08
Quote:
Originally Posted by Ballistics View Post
Will the 282 cam need to be custom ground?
COMP Cams 35-522-8 Ford 5.0 Xtreme Energy XE 282 HR
no the box will kill the torque
aode08 is offline   Reply With Quote
Old 01-31-2014, 05:20 AM   #33
Ballistics
Ballistics's Avatar
Local machine shops want upwards of $300 for angle milling. I'm considering just going with the TFS top end kit and call it a day.
Old 01-31-2014, 11:16 PM   #34
aode08
Don't forget, the tfs head might need tfs pistons, that requires the whole engine be removed and broke down, ask them if you need them
Old 02-03-2014, 12:51 PM   #35
jsimmonstx
jsimmonstx's Avatar
"Speed" and "budget-build" are diametrically opposed terms. Save your money and build a 351w stroker for the car. Expect to spend at LEAST $7k, and that's if you cheap out and get a cast bottom end (as opposed to forged), and then get lucky a nd stumble into a good deal on used intake/carb). You can spend less money on less capable heads as well, but AFRs are the hot ticket, and even if you use their 205's, you should see AT LEAST 400HP at the rear wheels with a knobby bump stick. The benefit of the 351w is that it doesn't have to work as hard to get more power.
jsimmonstx is offline   Reply With Quote
Old 02-04-2014, 03:24 PM   #36
aode08
Talking
Quote:
Or as hard to get you speeding tickets
Old 02-06-2014, 10:06 PM   #37
Ballistics
Ballistics's Avatar
TFS kit is ordered.
Still need to pick up a fuel pump and regulator and throttle body.
Old 02-09-2014, 05:47 AM   #38
Ballistics
Ballistics's Avatar
OK, what size injectors,TB,MAF,and Fuel pump should I be getting?
I was thinking 190lph fuel pump would be good, along with a 75mm TB and MAF and 24lb injectors? Or should I go 30lb?
Old 02-11-2014, 09:12 AM   #39
aode08
Wink
70mm throttle body, 24lb injectors, 190 lph fuel pump, matching mass air.
Cam swap on 68 289 ding56 Classic Mustangs (Tech) 3 08-14-2015 03:40 AM
engine swap 69 classic69FB Motor Swap Section 1 08-13-2015 12:58 AM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
Motorcraft spark plug Glyn 5.0L (1979-1995) Mustang 2 08-07-2015 11:41 PM
