oil pressure - MustangForums.com
Old 01-26-2014, 08:20 PM   #1
5overt
Default oil pressure
no oil pressure. gauge reads zero pulled valve cover started it up no oil squirting thru push rods. motor sounds dry. oil pump for sure or something else before i jerk motor out to put in oil pump
5overt is offline   Reply With Quote
Old 01-26-2014, 09:15 PM   #2
rmodel65
Yukon Cornelius
rmodel65's Avatar
probably the oil pump driveshaft sheared its pretty common on the 289/302/351w motors
rmodel65 is offline   Reply With Quote
Old 01-26-2014, 09:59 PM   #3
5overt
well I tried to spin it with a drill seems to be locked up. is that shaft supposed to be a spiral or hexagon?
Old 01-26-2014, 10:54 PM   #4
reldla1996
It should be hexagon. If it's spiral, something has locked the pump up - I had one do the same thing a few years back. You don't have to pull the engine to pull the pan and replace the pump and/or pump shaft; though it's a lot messier to do in the car....
reldla1996 is offline   Reply With Quote
Old 01-26-2014, 10:56 PM   #5
5overt
well I was going to do rear main fron etc tranny needy work this just made evrything else a priority as well
Old 01-27-2014, 05:28 AM   #6
barnett468
Quote:
its not locked up. if it was the shaft would be broken or twisted like a pretzel etc. its a 1/4 inch 6 point.
barnett468 is offline   Reply With Quote
Old 01-27-2014, 05:48 PM   #7
5overt
I am a blacksmith and the rod is twisted like that of decorative iron on burglar bars. no longer the once stock hexagon shape......the drill would not budge the pump
Old 01-27-2014, 08:03 PM   #8
reldla1996
Once upon a time, my oil pump drive shaft was as you describe, except with extra twist compared to twisted decorative wrought iron.
Old 01-27-2014, 09:12 PM   #9
5overt
the term changes from twisted to SPUN!
Old 01-28-2014, 12:20 AM   #10
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Quote:
Originally Posted by barnett468 View Post
its not locked up.
it's locked up, nuff said..........................op make sure there is not a lot of metallic in the oil, may want to cut open filter as well to see if bearing material is in it ...if none seen, change the pump and hopefully you dodged a bullet
mjr46 is offline   Reply With Quote
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 12:39 PM
TNT weekend - No PB, just fun..... 88 orangepeel notch Street/Strip 4 10-05-2015 10:03 AM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
1995 Mustang GT RAM HDX / TOB noise problem after install? ccdguy 5.0L (1979-1995) Mustang 1 09-19-2015 06:20 PM
Diagnosing Fuel Pump & Pressure SteelerNation82 V6 (1994-2004) Mustangs 1 09-16-2015 08:11 AM
