No, that's usually motor related. Could you describe the "running rough" in more detail. Example: hot or cold motor, idling or under a load, misfire or vibration ?
the motor seems to bog down under a load as it warms up.sometime it will pop back through throttle body I am guessin the timiming could be off.it runs smooth at idle,could it be off 1 tooth and run smooth at an idle
thanks,i don't know why that comp was in there I have found a lot of stuff that previous owner didn't tell.i will check timing marks when I can,i just had neck surgery.Do you know much about aod tranny
Not to much, my car had built AOD when I bought it and I didn't mind it at all. It was very consistent at the track. But they don't like abuse if their not built for it. I'm much happier after I swapped in the T5. What would you like to know about the AOD, someone here will have an answer.
