posi rear end ?
Old 02-09-2014, 06:19 AM
swanny
swanny's Avatar
Default posi rear end ?
I have an 89 lx with carbureted 306 and posi only works when turning left. I was wondering because I want to replace posi how to tell or maybe u guys know if isa 8.8 31 or 28 spline. it has a 4 lug wheel if that matters
swanny is offline
Old 02-09-2014, 02:13 PM
uedlose
uedlose's Avatar
pull a axle and count the spines. then you will know. if it is a stock rear it will be 28s
uedlose is offline
Old 02-09-2014, 06:53 PM
swanny
swanny's Avatar
I believe its stock so thank u . I want to order parts so I can put right back together
swanny is offline
Old 02-10-2014, 06:50 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Ifs its a stock trac-loc just spend money on the clutches ~$70. Should be the same for 28 and 31 spline units.
Boss_Hotrod is offline
Old 02-10-2014, 10:07 AM
uedlose
uedlose's Avatar
^^ boss is on it.
uedlose is offline
Old 02-11-2014, 06:27 AM
swanny
swanny's Avatar
where are u finding clutches for 70 dollars ? I found them on jegs for 100$
swanny is offline
Old 02-11-2014, 06:28 AM
swanny
swanny's Avatar
i was going to just buy the whole trac lock. how hard are the clutches to change?
swanny is offline
Old 02-11-2014, 02:36 PM
uedlose
uedlose's Avatar
they are not bad the worst part is the S spring other then that cake work to me anyway.
uedlose is offline
Old 02-11-2014, 03:15 PM
Boss_Hotrod
They use to be $69. Guess they have gone up. Been a few years since I bought a set.
$75 at 5.0 resto. Carbon discs are $108.
http://www.latemodelrestoration.com/...Lok-Clutch-Kit
Old 02-11-2014, 06:01 PM
swanny
swanny's Avatar
K Thanks I think ill attempt it. the guy I bought car from said it is original rear end 5.0 efi originally then 351 now 306 carbed with 351 on stand
swanny is offline
Quick Reply: posi rear end ?
