Charging Issue. PLEASE HELP ME!!! :( - MustangForums.com
Old 02-21-2014, 01:26 AM   #1
Spriggs01
Spriggs01's Avatar
Default Charging Issue. PLEASE HELP ME!!! :(
Im having a problem with my charging system.... So ive tried just about everything, new alt, battery tested good, also added a 1/0 wire off the neg term, gleaned up the ground going to the block, checked all around in and out of the car for loose wires, shorts, etc. The car has its moments, sometimes it fires right up, sometimes it clicks then its dead. All the connections to the starter, battery, solo, alt are ok. I even pulled the stereo out and capped off all the wires, theres no ligths staying on. while it idles, the battery drains, lights are dim, everthing dims. Ecspeciallly when the heater is turned on, or even the blinker. Some people say it could be the underdrive pullies, but idts... The belt is tight, also new. Please someone thats had this problem before help me out.. Its so embarrising when i have to push and jump the car all the time... im pretty mechanically inclined but cant seem to find the problem, thanks
Spriggs01 is offline   Reply With Quote
Old 02-21-2014, 08:51 AM   #2
88 orangepeel notch
88 orangepeel notch's Avatar
So just to clarify, you ARE running underdrive pulleys? Because they do kill the charging at idle. It sounds like you've checked everything, but curious how you checked a battery drain while at idle. Can you give us any volt readings that your checking, have you did a load test on the new battery? Sometimes new doesn't mean it's good.
88 orangepeel notch is offline   Reply With Quote
Old 02-21-2014, 09:49 AM   #3
Spriggs01
Spriggs01's Avatar
I just got it tested at autozone, the battery is good. Hte altenator is what was new, and i appreciate the reply! And the battery was reading 12.7 V not sure about the alt, but the last time i checked it it was around 12v which is low, but not too low. I put three alts on there, one after another to try and see if that was the pronlem. But like i said alot of people have said it could be the under drive,, anyway to get around without swapping them back to stock? When it idles, the batt reading staedily drops, if it idles awhile and i cut it off it it wont start, sometimes even idles till it dies..
Old 02-21-2014, 10:14 AM   #4
dawson1112
You know IIRC there is a fusible link in the charging system some where that when it goes bad he system will not charge. Maybe some one here has that diagram , but I will look for it I know I had it some place saved on my computer .
dawson1112 is offline   Reply With Quote
Old 02-21-2014, 10:23 AM   #5
Spriggs01
Spriggs01's Avatar
Ok ill try and look for one, thanks for the reply. If you come across one please do post it, id appreciate it alot. Thanks again
Old 02-21-2014, 07:38 PM   #6
mongolchuck
What year is the car?
mongolchuck is offline   Reply With Quote
Old 02-21-2014, 07:42 PM   #7
Spriggs01
Spriggs01's Avatar
Quote:
its a 92
Old 02-21-2014, 08:02 PM   #8
mongolchuck
Sorry. I see now under your avatar. The main wire off the alt is black/orange that becomes green as it winds its way to the starter relay. The fusible link is closer to the starter relay. check and make sure you have power (12v) to the yellow wire on the alt. The yellow wire has a separate fusible link off the green.
Old 02-23-2014, 11:34 AM   #9
aode08
With a volt meter, if you get 12.7 at idle, then rev it up, now you have 14 volts or close, the under drive setup is slowing the rotation of the alternator down.
No matter how tight the belt is, its simply spinning too slow.
Easy fix, go back to stock, or instal a 3g/4g setup alternator like I did and OPTIMA red top battery.
If you have a boom box system, instal a 1.0 or so Farad Capacitor.
The 5.0 electrical system really sucks *****,add things like under drive pullies, and boom box, you've just skinned the cat.
aode08 is offline   Reply With Quote
Old 02-23-2014, 04:35 PM   #10
Spriggs01
Spriggs01's Avatar
Ok thanks! So where could I find a set of stock pullies? I can't find them anywhere! If you could give me a sight or link that'd be awesome. Thanks
Vintage AC shop referral - frontrunner serpentine system bradleyb Classic Mustangs (Tech) 3 11-27-2015 08:50 PM
Possible Clutch Issues..? Thunderball 4.6L (1996-2004 Modular) Mustang 15 11-23-2015 12:49 AM
2005 Mustang - Transmission rattle and slippage/stuttering AmericanMuscle4.6GT 2005-2014 Mustangs 7 11-10-2015 03:06 PM
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 02:02 AM
