Spark plug gap questions - MustangForums.com
Old 03-03-2014, 10:13 AM   #1
whtbullitt
Default Spark plug gap questions
When I installed the TFS 185cc heads last spring Trick Flow said to run the Autolite 3924's gapped at .045 with the factory ignition.
This spring I am upgrading to an MSD coil, TFI module and new cap/rotor and wires but no ignition box.
Will adjusting the gap be worth it and what gap is recommended?
I only picked up .3 and 3 mph with the heads and I am very disappointed at this point.
whtbullitt is offline   Reply With Quote
Old 03-03-2014, 12:59 PM   #2
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
your heads are not the problem, nor the gap on the plug, your bottle neck lies in the gt-40 intake and b-cam and exhaust could play a factor depending on the size as well......while the gt-40 intake still performs well for a 20+ year old intake, it's lower is quite restrictive, when I do a motor, I port match everything as well as look at all the little things, there's a difference between an egine builder vs assembler
mjr46 is offline   Reply With Quote
Old 03-04-2014, 03:37 PM   #3
whtbullitt
Talked my wife into letting me ship my lower to Tmoss to get done so that should help some.
Labor Day Weekend Special Granatelli Sales GT S197 General Discussion 5 03-25-2016 08:01 PM
Spark Plug Change 2007StangV6 2005-2014 Mustangs 30 01-28-2016 06:09 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 10:45 PM
HELP A/C Wont blow cold, electrical 2008 cbird1177711 2005-2014 Mustangs 0 09-02-2015 04:12 PM
