Spark plug gap questions
Old 03-03-2014, 10:13 AM
whtbullitt
whtbullitt's Avatar
Default Spark plug gap questions
When I installed the TFS 185cc heads last spring Trick Flow said to run the Autolite 3924's gapped at .045 with the factory ignition.
This spring I am upgrading to an MSD coil, TFI module and new cap/rotor and wires but no ignition box.
Will adjusting the gap be worth it and what gap is recommended?
I only picked up .3 and 3 mph with the heads and I am very disappointed at this point.
whtbullitt is offline
Old 03-03-2014, 12:59 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
your heads are not the problem, nor the gap on the plug, your bottle neck lies in the gt-40 intake and b-cam and exhaust could play a factor depending on the size as well......while the gt-40 intake still performs well for a 20+ year old intake, it's lower is quite restrictive, when I do a motor, I port match everything as well as look at all the little things, there's a difference between an egine builder vs assembler
mjr46 is offline
Old 03-04-2014, 03:37 PM
whtbullitt
whtbullitt's Avatar
Talked my wife into letting me ship my lower to Tmoss to get done so that should help some.
Granatelli Sales
03-25-2016 08:01 PM
2007StangV6
01-28-2016 06:09 PM
Emblazoned
09-03-2015 10:45 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Spark plug gap questions
