Keep breaking clutch cable. Wrong quadrant hook?
Are you saying that the quadrant is aligned at an angle so the cable rubs on the side when it goes through the firewall? I don't know why this would make it break...but okay, elaborate.
Also, the last time the new cable broke, it was when I was just sitting in traffic for a while and the car was getting really hot. Also, the car is black so now once I think, it makes sense that maybe it broke because of the heat.
Pull your quadrant out and look at it. I bet you'll see wear marks on it, as to where it has bound and chaffed your cable.
Once I swapped away from a multi-hook quadrant, I never broke a cable again. I was running a cheap adjustable too. the ones that nobody ever has luck with.
yet, with my multi-hook, i broke about 7 cables.
I had a UPR triple hook in it when I bought the car and yes the cable rubbed it and broke at the quadrant. The 2nd one I had broke the sheathing outside just past the adjuster. Looked like it got skinned. Hadnt had either issue with the MM stuff.
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
