Junker is Smoking
Junker is Smoking
I have a 88 gt i have all kinds of work done to it and i keep getting gas in the oil how can i tell why its running so rich without speending money on a air/fuel mix gauge and i need to now if there is a way to monitor fuel trims thanks
Junker is Smoking
get a fuel pressure gauge but if you have made alot of mods with that speed den. 'puter you will be always chasing it.
oh by the way you will always have some gas in the oil<edited><editID>vfast</editID><editDate>37976.6990393519</editDate></edited>
Junker is Smoking
hook up at leakdown tester and listen in the oil dipstick entry for a leak (make sure you are at TDC). if you hear the hiss you have bad rings. could also be PVC <IMG src=smileys/smiley16.gif border="0">. </P>
Junker is Smoking
Ok well i should have said i made it mass air and i have new rings and no blow by for two reasons first is i already leak tested alll cylinders and have no leaks and second is to start the car you have to clear flood mode it by slamming the pedal to the floorso I can get the fuel out of the cylinders
01-21-2016 01:30 PM
