Broken block behind timing cover?!?! Help!!
Old 03-25-2014, 09:33 PM
BlackStallion5.0
BlackStallion5.0's Avatar
Default Broken block behind timing cover?!?! Help!!
Hey guys I'm at a loss here...I'm coming close to finishing my build and as I was tightening up my water pump bolts the block split(pic attached). Can anyone tell me if I can run it like this or if I can fix it or if I am completely screwed. Any help is greatly appreciated.
BlackStallion5.0 is offline
Old 03-25-2014, 11:16 PM
barnett468
barnett468's Avatar
you are screwed beyond belief.
you can buy another block
you can disassemble yours and have it welded properly.
you can remove the timing cover and have it welded in the car and pray it works.
it broke in the threads so you might have to helicoil the hole after.
that bolt only needs around 18 lbs of torque
i have never seen one break there. it would likely take a grade 8 bolt with too much torque on it or a bolt that is too long and bottomed out to break it etc..
barnett468 is offline
Old 03-26-2014, 06:20 AM
BlackStallion5.0
I was using a torque wrench at exactly 18ft pounds when this happened and it was the exact bolt that came out of It the first time....there has to be something I can do.....
Old 03-26-2014, 06:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there is, ...........get another block
mjr46 is offline
Old 03-26-2014, 08:18 AM
BlackStallion5.0
I understand that getting a new block is the best option but unfortunately I've put everything I have into this one. This car is going to have to be my daily driver for awhile so I almost don't have a choice but to try and fix it. Is there anyone out there who has dealt with this before and successfully repaired the problem?
Old 03-26-2014, 08:33 AM
dawson1112
dawson1112's Avatar
Chances are that a new block is going to be the only logical option.
start it drive it run it, if it leaks ... get a new block. I doubt you will find any welding shop that will even attempt to try to fix it. If by chance you do find a welder with cast iron experience they are going to charge you a fortune and then they wont even guarantee the work , because they know welding cast is absolutely incredibly difficult .
Oh and chances are that crack will continue to grow with vibrations ,,,, bite the bullet and find a new block.
dawson1112 is offline
Old 03-26-2014, 09:13 AM
88 orangepeel notch
88 orangepeel notch's Avatar
That sucks the big one, but you know you'll have a coolant puddle everywhere you stop. It will never seal, and I've never saw one crack there either. Could have been hit or something dropped on it while apart?
88 orangepeel notch is offline
Old 03-26-2014, 09:22 AM
BlackStallion5.0
It would be hard to say at this point as to what could have happened. I know I was always very careful with it. I'm sick over this...I don't have the time or money to get this
Old 03-26-2014, 09:23 AM
BlackStallion5.0
....fixed anytime soon. Is what I was trying to say.
Old 03-26-2014, 01:20 PM
88 orangepeel notch
Yeah, I keep looking at that picture trying to think of anything to fix it and there's just nothing that would be a solid fix. You can't drill and tap any deeper without breaking into the waterjacket, welding would be next but you really have to know what your doing with cast.
There's always JB Weld lol.
Quick Reply: Broken block behind timing cover?!?! Help!!
