Need Help With Install Of Bbk Ssi Lower Intake On My 88 Fox 302
Old 03-31-2014, 02:17 PM
timeball63
timeball63's Avatar
Default Need Help With Install Of Bbk Ssi Lower Intake On My 88 Fox 302
Hi I just have a few quick questions on this install and some of this community imput on my setup. I just dropped in some aluminum gt 40x heads with some crane cam 1.7 ped mount roller rockers. i am already runing a ford racing f 303 cam. heads are on and torqued down to spec. so I just finished puttinuig together the fuel rails and injectors on the lower and ready to install it to the heads. I notcied the hardware kit that came with the intake does not have the lower mounting bolts. Should I just use the old ones with these heads? Or should I order new ones? If so what should I order.? And I also have another question regarding my the injectors. I am installing 30 lbs injectors with a 73mm cailibrated MAF will this be to much fuel for my set up? Thanks
timeball63 is offline
Old 03-31-2014, 02:30 PM
dawson1112
dawson1112's Avatar
You can reuse the lower intake bolts , but I suggest using some silver anti seize on the bolts any time you put steel bolts into aluminum threads.
The injectors will be fine, I run 30lb injectors on my setup with a calibrated maf housing .
dawson1112 is offline
spectreman
03-31-2016 09:26 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Calizic
08-28-2015 01:46 PM
12bigredstang
08-25-2015 04:58 PM
Mustangs of Illinois
08-22-2015 10:00 PM
Quick Reply: Need Help With Install Of Bbk Ssi Lower Intake On My 88 Fox 302
