did a compression check today - Page 2 - MustangForums.com
Old 04-22-2014, 02:31 AM   #11
95greengt
95greengt's Avatar
Hack ... I use conventional oil now. I have heard in the past that you should not switch a motor over to synthetic after it has been ran for a while with conventional. Why is it that the synthetic would cause it to not smoke?
95greengt is offline   Reply With Quote
Old 04-23-2014, 02:39 AM   #12
tinman
Rule of thumb........
When checking compression all the cylinders should be within 10% of each other.
That applies to everything BTW.....
tinman is offline   Reply With Quote
Old 04-24-2014, 03:50 PM   #13
HACKGT350
HACKGT350's Avatar
that is a bunch of bull. you can run synthetic at any time. when the car hasnt been taken care of it can cause the engine to leak by breaking down the sludge in the engine that car blocking up leaks. other than that your engine will never know the difference if you run synthetic or conventional. and you can switch back to conventional
HACKGT350 is offline   Reply With Quote
Old 04-25-2014, 05:53 AM   #14
95greengt
95greengt's Avatar
Quote:
May be something i look into then... Thanks Hack
Car died while driving... StalkerGT 5.0L (1979-1995) Mustang 13 09-25-2015 03:41 PM
cylinder compression bconboy 2005-2014 Mustangs 16 09-21-2015 01:52 PM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 01:08 PM
Opinions on Recaro Seats???? Mr. D Off Topic 15 09-11-2015 03:29 AM
Weird electrical/battery issue?? Mobiusone stang 2005-2014 Mustangs 7 09-07-2015 09:46 PM
