did a compression check today
Old 04-11-2014, 01:18 PM
95greengt
95greengt's Avatar
Default did a compression check today
So i did a compression check today and i am looking at 138 to 145 on a cold motor. From what i have read this doesn't seem to bad. The reason i did a compression test is the car started smoking a little bit and before throwing money and time into valve seals i wanted to check and see if it was something like rings or a valve hanging open on me.
Does the compression readings i got seem ok? Just want to make sure before i proceed.
95greengt is offline
Old 04-11-2014, 01:40 PM
88 orangepeel notch
88 orangepeel notch's Avatar
Id be very happy with those #'s, nice and even.
88 orangepeel notch is offline
Old 04-11-2014, 02:12 PM
95greengt
95greengt's Avatar
Thats what i was thinking... Would i be better off to remove the heads to change the valve seals? I have never had the heads off of this motor. It would give me a chance to check it out and see how it looks on the top side. Or should i just change them with the heads still on?
Old 04-11-2014, 04:24 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
change them with heads on....to much extra work
mjr46 is offline
Old 04-11-2014, 09:31 PM
95greengt
95greengt's Avatar
Being that I will have the rockers off anyway would it be beneficial to add a set of roller rockers while I am in there? I know the gains will be slight but it would be something to go with any other mods I do in the future.
Old 04-11-2014, 10:16 PM
barnett468
barnett468's Avatar
hello
well how many miles are on it?
if its around 170 or more your valves might leak soon anyway.
if you yank the heads you can do a valve job check the guides, redo the seals, inspect your cylinder bore for a slight ridge near the top which is an indicator the the bore is pretty worn and you can mill those heads .028 from stock to bump your compression up around .5.
i would buy scorpion rollers if you want some. they will do little to indreae hp.
if they are 1.6 ratio, you can install 1.7 to possibly boost your hp but i would not do it.
barnett468 is offline
Old 04-12-2014, 04:24 AM
95greengt
95greengt's Avatar
Barnett ... why is it that you would not go with 1.7s? wear.. clearance issues...
Old 04-12-2014, 04:25 AM
95greengt
95greengt's Avatar
it has about 95000 on it now
Old 04-12-2014, 07:20 PM
barnett468
barnett468's Avatar
thats just me. cams are designed to run with a certain ratio rocker. its rare that changing ratios will improve a cams overall performance.
the fact that your car has a stock cam is an exception. it is designed to meet epa requirements etc, therefore, installing 1.7's might benefit you.
if it was me i'd simply pull the heads, do the work and put in a real cam.
Old 04-19-2014, 09:10 AM
HACKGT350
HACKGT350's Avatar
you have under 100k miles on the engine. i would just leave the heads on the car, change the valve seals and the rockers to roller rockers. also do you use conventional oil or synthetic? if you use conventional switch to synthetic and i bet you wont see any more smoke out the exhaust.
HACKGT350 is offline
Quick Reply: did a compression check today
