pulley system issues
Old 04-19-2014, 04:40 PM
ponynewb90
ponynewb90's Avatar
Default pulley system issues
Just got a '99 mustang with a 302 in it, not sure what year the 302 is but for some reason the pulley system isn't lining up and the belt is too small in width. is there a quick fix to this issue and would this issue cause the radiator to over heat?
ponynewb90 is offline
Old 04-19-2014, 05:00 PM
dawson1112
dawson1112's Avatar
Pictures would help. but if the belt is slipping on the waterpump then yes it could cause an over heat.
I assume the car is an old carbureted 302?
dawson1112 is offline
Old 04-19-2014, 06:51 PM
ponynewb90
ponynewb90's Avatar
Does this help? And correct on your assumption
Old 04-19-2014, 07:01 PM
ponynewb90
ponynewb90's Avatar
Also could i just order pulley spacers to bring the crank and water pump pulley out?
Old 04-20-2014, 07:06 AM
dawson1112
dawson1112's Avatar
Just from looking at that picture I can tell you why it over heats. There is not enough surface contact of the belt on the water pump and it is likely slipping.
That alternator needs to be on the other side of the engine, I don't think I ever seen a 302 with it on the drivers side.
You have a lot of reconfiguring to do.
When I did my old 68 302 in the 95 mustang I had I used a double crank pully and 2 separate ribbed belts . 1 to drive the alt and and water pump and 1 to drive the power steering pump. The kit was kind of expensive and if I had it to do again I would go to the junk yard and get the bracket from a wrecked 94-95 mustang.
You could probly get away with a longer belt and adding an idler pulley to the passenger side of the engine so that the routing looks like this below.
As for the alignment problem I think they used a 5 rib belt in place of a 6 rib belt just so it would line up with the pulleys As long as the belt isn't squealing or jumping off it should be ok, but I would personally reconfigure the entire system by getting the brackets and pulleys from a junk yard for a sn95 5.0.
Old 04-20-2014, 11:46 AM
ponynewb90
ponynewb90's Avatar
thanks man i really appreciate the input ill look into getting the pulleys and everything straightened out
Granatelli Sales
03-21-2016 06:16 PM
ctgreddy
09-20-2015 08:35 PM
MusicCity615
09-12-2015 07:05 AM
09-10-2015 08:39 PM
uedlose
09-10-2015 03:30 PM
Quick Reply: pulley system issues
