Fuel pressure regulator
Old 02-26-2014, 07:05 AM
Charlieg3
Charlieg3's Avatar
Default Fuel pressure regulator
1990 gt, t5, trick flow heads, 30 lbs injectors. The car has run great since I bought it 6 months ago. Recently is has had an enginemmiss under load, and it feels like it is shutting off when you go to wide open throttle. I installed a new 255 LPH fuel pump when I bought it. Fuel pressure reads 36 at idle, 40 when the vacuum hose is unhooked. In second gear at 2000 rpm pressure is 32 psi, at 4000 rpm pressure drops to 25, and it takes a while to build pressure back up over 30 psi. Any suggestions, fuel pressure regulator, pump, vacuum leak?
Charlieg3 is offline
Old 03-01-2014, 02:50 PM
StalkerGT
StalkerGT's Avatar
I had a similar problem and it was the regulator...I would put an adjustable in since you have heads and injectors..etc
StalkerGT is offline
Old 03-02-2014, 05:41 PM
zbbow1974
zbbow1974's Avatar
i have the exact same issue, i installed a new regulator and the issue remains, i do hear a vaccume leak at the firewall on the drive side, got to put new head gaskets on my ride so i will tackle the leak when i do those, post a reply if the regulator is your issue please
zbbow1974 is offline
Old 03-04-2014, 07:57 PM
Charlieg3
Charlieg3's Avatar
The car runs the same with the fuel pressure regulator hooked up or unhooked to the vacuum hose.
The fuel filter is clean, but I need to check the sock on the fuel pump.
Old 04-22-2014, 07:06 AM
Charlieg3
Charlieg3's Avatar
Turns out the fuel pump was bad, replaced it and it is running fine.
Old 04-22-2014, 10:42 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Good to hear, and thanks for the update.
88 orangepeel notch is offline
mrtrodonet
09-19-2020 03:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel pressure regulator
