Car runs bad and check engine light after replacing distributor
Old 04-30-2014, 01:44 AM
MacSerio
MacSerio's Avatar
if there is any suction, it is very minute and i cant feel it. But i went ahead and changed the oxygen sensor because the wires were cut and spliced back together(like a car stereo), and now im getting codes 34 44 and 94. Where does this point me exactly?
MacSerio is offline
Old 04-30-2014, 01:45 AM
MacSerio
MacSerio's Avatar
Thank you all for the input!! btw
MacSerio is offline
Old 04-30-2014, 09:55 AM
Boss_Hotrod
Boss_Hotrod's Avatar
44 and 94 are for the AIR pump. dont worry about those. the 34 is EGR valve position sensor. Be sure its plugged in. From what I can remember if the sensor is plugged in and the vac line is off the system just deletes the function and does not make the light come on. Sounds like you may need to start checking other things on the car. Check your firing order and make sure the dizzy is stabbed correctly. Double check timing also.
Boss_Hotrod is offline
Old 04-30-2014, 03:51 PM
MacSerio
MacSerio's Avatar
ok ill redo the distributor one more time and double check f-o. lets see what happens...
MacSerio is offline
Old 04-30-2014, 08:41 PM
MacSerio
MacSerio's Avatar
i just set the dizzy on tdc, it wasnt pointing exactly on number one spark plug, it was slightly off, but it was at 0 on balancer.. is that ok?my timing is set to about 8. and i am getting vacuum at idle from the line that plugs onto the egr. What does that mean? why is it getting vacuum when its not 'supposed to' be?
MacSerio is offline
Old 05-01-2014, 02:54 AM
MacSerio
MacSerio's Avatar
Thumbs up
THE FIX: For me it was clogged valves on the air solenoids, i cleaned all three of them out and tightened up some vacuum lines and it works fine now, no more vacuum at idle, only a very little. idles much better, still have a slight idle jump i can see at the gauge, but its 50 times better. Thanks for all the input and assistance to everyone.
MacSerio is offline
Old 05-01-2014, 08:20 AM
Boss_Hotrod
Set your base timing to about 12-14*. Car will run a lot better. Just be sure it doesnt spark knock.
djbigskrilla
09-20-2022 01:04 AM
NorthAmericanTuning
03-18-2016 11:21 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
J.casone400
08-07-2015 08:40 PM
Quick Reply: Car runs bad and check engine light after replacing distributor
