19lbl or 24lbl Injectors? - MustangForums.com
Old 04-22-2014, 03:25 PM   #1
yurizx6r
yurizx6r's Avatar
Default 19lbl or 24lbl Injectors?
Hey guys sorry to ask a tired question, but I just needed to double check to make sure I get the right parts. I was wondering two things: 1. what size injectors I need and 2. do I need an adjustable fuel pressure regulator? My engine mods are: BBK CAI, C&L 73mm MAF, 70MM TB, Edelbrock EFI intake manifold, and a full off road exhaust.
yurizx6r is offline   Reply With Quote
Old 04-22-2014, 03:58 PM   #2
dawson1112
19s are fine your not making near enough power to justify the expense of changing to 24lbs. IF you plan on getting some better than stock heads and a cam later 24s might be of some help.
with the set up you have now you don't need an adjustable fpr either.
dawson1112 is offline   Reply With Quote
Old 04-22-2014, 06:31 PM   #3
reldla1996
I second Dawson's opinion.
reldla1996 is offline   Reply With Quote
Old 04-22-2014, 06:56 PM   #4
bluebeastsrt
bluebeastsrt's Avatar
Good advice mentioned above. Good luck with the new parts.
bluebeastsrt is offline   Reply With Quote
Old 04-22-2014, 09:26 PM   #5
yurizx6r
yurizx6r's Avatar
Excellent! I thought so as well, but I was not sure.
Old 04-23-2014, 08:03 AM   #6
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you have no real mods to warrant larger inj's
mjr46 is offline   Reply With Quote
Old 04-23-2014, 02:04 PM   #7
yurizx6r
yurizx6r's Avatar
I think you guys are right, the choke point is certainly the heads and until those are upgraded I don't see the need. I just was not sure because all that I know is the 80% duty cycle on the 19lbl injectors are 285hp, but how are you REALLY supposed to know besides a dyno or wide band meter?
Old 04-23-2014, 10:40 PM   #8
bluebeastsrt
Quote:
A wideband only tells you your air/Fuel ratio. Doesn't measure horsepower.
Old 04-24-2014, 02:12 AM   #9
barnett468
hi;
that's easy, computer dyno syms and years of experience.
you need a cam to match head flow. just increasing head flow will not do a ton for you.
barnett468 is offline   Reply With Quote
Old 04-24-2014, 09:49 AM   #10
88 orangepeel notch
88 orangepeel notch's Avatar
I was gonna stay out of this one because everyone gave the right answers. But here's my .02.
My car makes 300 at the wheels, or 340-345 at the crank. I'm still running 19's, should I get 24's……yes. But I'm getting up in the years and getting tired of the wrenching. I have a Anderson PMS that tells you the injector duty cycle, also a wideband. For everyday, normal driving my duty cycle rarely goes over 30%, 60% during an onramp romp to freeway speeds.
Now my car does see the track 2-3 times a year, where my duty cycle is maxed out for 1-2 seconds at the top of 2nd gear. 1st gear is over before a blink, and I shortshift the 3 to 4 because of my gearing. My wideband shows no sign of any lean condition. I was told that an injector can take a short burst of 100% duty cycle. Its the prolonged runs like road racing that will burn them up.
That being said, I'm going to our huge bi-annual swap meet tomorrow looking for 24's and calibrated MAF. Better save than sorry.
88 orangepeel notch is offline   Reply With Quote
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 06:52 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
91 vert tailpipe smoking MacSerio 5.0L (1979-1995) Mustang 3 09-27-2015 02:05 PM
Need new cats? mltdwn12 V6 (1994-2004) Mustangs 1 09-23-2015 09:54 AM
