1989 mustang brake issue
Old 05-12-2014, 09:57 PM
mustanggtrich
mustanggtrich's Avatar
Exclamation 1989 mustang brake issue
I have a 1989 mustang GT .Did the brake convertion to disk in rear and now 5 bolt patern .Bought kit fron SSBC But since the convertion i cant get car to stop .Called manufacture did everything correct even brought to garage and the can't figure it out. NEW BACK BRAKES NEW FRONT CALLIPERS everything is new .Can anyone help .
Rich
mustanggtrich is offline
Old 05-12-2014, 11:01 PM
dawson1112
dawson1112's Avatar
Explain more.
Did you bleed them properly? How does your pedal feel?
dawson1112 is offline
Old 05-13-2014, 08:44 AM
yurizx6r
yurizx6r's Avatar
Did you upgrade the master cylinder too? I just did a huge SN95 Cobra/5 lug upgrade too. If you go from drums to rear disc brakes you need to upgrade to a 1" master cylinder. The 93 Cobra master cylinder is the best overall one you can get and it will bolt right up. Go to maximum motorsports to get all the hardware you need to upgrade it. Also, you may have to get a adjustable proportioning valve.
yurizx6r is offline
Old 05-13-2014, 10:50 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Id say either wrong master cylinder (pedal will travel too far) or proportioning valve not right. If you have an adjustable one the base setting is 3 turns in from all the way out.
Boss_Hotrod is offline
Old 05-13-2014, 11:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
please define "can't get it to stop" meaning add more details ?? pedal feel?? how is the travel of the pedal?? bled properly?? if not pedal will feel spongy..........proper master cylinder......?? proportioning valve set right?? ect ect.....need more info on all the symptoms
mjr46 is offline
Urambo Tauro
09-07-2015 12:47 PM
FD725
08-23-2015 06:43 AM
daytooday
08-11-2015 09:22 AM
FD725
08-11-2015 03:43 AM
cema93
08-10-2015 09:35 PM
Quick Reply: 1989 mustang brake issue
