vss help and connections
Old 05-19-2014, 05:56 PM
Goosepoop302
Goosepoop302's Avatar
Default vss help and connections
hey guys couple quick questions. what is the vehicle speed sensor control?is it only a sensor or does it influence other parts of the computer. I ask because I pulled mine out and it was clearly Worn on one side. I've been having issues with hanging idle and the IAC acting funny. is there any connection between these two pieces? any information would be
Goosepoop302 is offline
Old 05-19-2014, 09:18 PM
reldla1996
reldla1996's Avatar
The vss will hold the engine to a fast idle with the transmission in neutral until the vehicle speed is zero, when it will allow the engine to drop to idle.
reldla1996 is offline
Old 05-19-2014, 09:30 PM
Goosepoop302
I believe my vss may have been malfunctioning as it is worn on one side.. it appeared it was to tight (whoops) and sat slightly crooked or with side pressure. I was having issues with hanging idle between shifts and slow idle fall (no vac leaks found, new iac, ect..) could this be part or all of my issue?
lincolnshibuya
10-06-2015 08:45 AM
Urambo Tauro
10-05-2015 09:37 PM
breaking
10-02-2015 01:27 PM
TfcCDR
09-14-2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: vss help and connections
