head bolt torque using arp bolts
torque on uppers using arp lube iirc is 75 and lowers is 80 if oil is used iirc you are suppose to up torque 5 ft lbs......arps website will have the specific values for the bolt part number you bought.
thanks again
http://arpinstructions.com/instructions/154-3601.pdf
also, in general, so now i torqued the head down, then a day later i went and torqued another 5 pounds or so. is the thread sealant ruined now, im guessing yes.
damn
if the thread sealant is ruined and/or if this teflon stuff is a must, do i need to start over? if so, can i re-use the head gasket?
this is turning into a minor nightmare
thanks again
What type of thread sealant did you use? If the sealant you used is approved for head bolts your fine. Loc-tite makes several products but if you using 5 dollar thread sealant your probably screwed. Teflon paste is the best to use because the lower bolts go into the water jackets and if you don't get a good seal you'll be leaking coolant all the time. If you have to start over the head gasket will be ok to reuse. If your not using a shop manual or at the very least a Haynes rebuild manual. It sounds like some think like that would come in handy for you.
used permatex, any good?
http://www.permatex.com/products-2/p...sealant-detail
says it can be adjusted up to 4 hours after applying, so i adjusted it more than 24 hours after, did i ruin it?
If they leak put a can of stop leak in it run it for a day or so and drain the system back out. then just refill the system with coolant. I done it many times with F/I engines due to not wanting to have the sealer mess up my torque values when torquing the head bolts and running MLS gaskets when customers would not up for studs. The engine in our turbo car when S/C started leaking at the bolts years ago so I did this and it was fine sealed right up. Now it is a R-block I dont have them issues anymore. But when ever I do a F/I engine with MLS gaskets I always put a can of stop leak in it run a day or 2 and drain it back out. Been doing it for years.
maestro1024
09-21-2015 02:40 PM
