95 a/c overheating issuse
Old 06-04-2014, 06:23 PM
cbalch
cbalch's Avatar
Default 95 a/c overheating issuse
ive got a 95 gt. so far i have changed on the a/c system the condenser accumulator the compressor has been rebuilt and the a/c hoses. i have replaced in the cooling system the radiator which is a 2 row aluminum and the fan assembly, both radiator hoses and thermostat (180 thermostat) and housing and the water pump. I had thought it was maybe due to a timing issue so i re timed it, it is now 10 degrees btdc. That did help a little it isn't overheating as fast or if its cool enough out side it will stay around 180. but if its hot it climbs up to 210 and passed 210. There are no leeks in the cooling system. My brother was saying that it could be the cylinder heads that are on it is causing it. they are off a Lincoln and have been milled down a bunch so i am clueless and need help.
cbalch is offline
Old 06-04-2014, 06:26 PM
cbalch
cbalch's Avatar
could higher compression cause overheating when the ac is on? any other time with the a/c off it stays around 180 or just above it.
cbalch is offline
Old 06-04-2014, 06:52 PM
dawson1112
dawson1112's Avatar
lol 210 is not over heating bud. Your still well with in normal at 220 even. I dont think the fans even kick on untill 215.
dawson1112 is offline
Old 06-04-2014, 06:53 PM
dawson1112
dawson1112's Avatar
Can I ask what your basing your temp readings off of?
The stock gauges are junk IMO.
Old 06-04-2014, 06:55 PM
cbalch
cbalch's Avatar
even if its getting closer into the 220 range? I'm not exactly sure what the temp is my gauge goes from 210 then there is a notch and then shoots up to 250 its been running at that notch in between the 210 and 250 and like i said it always runs around 180 with the a/c off.
cbalch is offline
Old 06-04-2014, 06:57 PM
cbalch
cbalch's Avatar
i have an aftermarket autometer guage the censor is in the intake closest to the distributor. i have an aftermarket trickflow track heat intake. and yeah i know the stock gauges are junk.
cbalch is offline
Old 06-04-2014, 06:59 PM
cbalch
cbalch's Avatar
usually after i let it get up to about 220 and park it i can smell the coolant and i can see that it has overflowed from the reservoir.
cbalch is offline
Old 06-04-2014, 07:23 PM
dawson1112
dawson1112's Avatar
Your fan should be kicking on by then . If not it will continiue to climb.
If you have pretty much replaced all of the major things like radiator , water pump thermostat, then I suggest you get a hydrocarbon tester and check for the presance of exhause gasses in your coolant .
Blown head gaskets are notorius for causeing over heating that can not be explained otherwise.
Old 06-04-2014, 07:43 PM
cbalch
cbalch's Avatar
i have replaced one head gasket once. Wouldnt a simple pressure test on the cooling system do the same thing? would more compression cause it to do this also?
cbalch is offline
Old 06-04-2014, 07:46 PM
cbalch
cbalch's Avatar
my fan is on all the time its set up to turn on with the car the stock fan harness wasn't kicking the fan on and my brother set it up on separate harness with a relay before i ever bought the car from him.
cbalch is offline
Quick Reply: 95 a/c overheating issuse
