1988 mustang convert manual to power window and lock - MustangForums.com
Old 07-29-2014, 12:49 AM   #1
leftyatm
Default 1988 mustang convert manual to power window and lock
Hey guys. What does this entail? And I am hoping that ford for cost sake wired all cars the same regardless of options. Can anyone please tell me if the cars that came with manual windows and locks were already prewired for power windows and locks?
Thanks!
leftyatm is offline   Reply With Quote
Old 07-29-2014, 06:35 AM   #2
dawson1112
It can certainly be done, but if your expecting to open the door panel and find existing wires and plugs for the lock solenoids and windows , that's not gonna happen. You will find a place in the fuse panel for them to be added , but that's as far as ford is gonna go.
Most likely you will need to change doors and add a harness from the fuse block .
dawson1112 is offline   Reply With Quote
Old 07-29-2014, 09:56 AM   #3
leftyatm
Damn. I thought I heard where there was a factory plug see here near the doors that a power window harness would be able to be plugged in.
Oh we'll thanks!
Old 07-29-2014, 03:13 PM   #4
Boss_Hotrod
There is a harness that runs behind the upper parts of the dash that houses the wires for the door locks and maybe the windows(cant remember on those) that a manual car probably wouldnt have. The dash harness itself might be the same. My 93 hatchback had wiring in it for a convertible top. Best thing to do is find an ETM and look up the wiring vs. your car. I bought an ETM off ebay years ago.
Boss_Hotrod is offline   Reply With Quote
Old 07-29-2014, 10:27 PM   #5
rmodel65
Yukon Cornelius
rmodel65's Avatar
be glad you have manual locks and windows so much better
rmodel65 is offline   Reply With Quote
Old 07-29-2014, 10:47 PM   #6
88Mach1
88Mach1's Avatar
you'd also have to change door panels too due to the arm rests being different
88Mach1 is offline   Reply With Quote
Old 07-30-2014, 04:43 AM   #7
leftyatm
Thanks guys. I did factor in that manual means less working parts to break. I just wanted to know my options.
Old 07-30-2014, 07:03 AM   #8
bluebeastsrt
bluebeastsrt's Avatar
Quote:
Haha exactly right. So much less headaches. I'm removing perfectly good working power windows just to drop a few pounds of race weight.
bluebeastsrt is online now   Reply With Quote
Old 07-30-2014, 09:34 PM   #9
rmodel65
Yukon Cornelius
rmodel65's Avatar
wish the gts had manual stuff but alas it was order optioned. i have a man drivers seat lol
Old 07-31-2014, 02:04 AM   #10
leftyatm
So you guys really prefer manual? Is it because it's one more part to break or because of weight savings?
I personally plan to go through the car too to bottom front to back over the next 10 years to make this thing new again. And for me, weight savings isn't an issue. I am not planning on racing it, I simply want a fun reliable fun car to be taken out on date nights, weekend cruising and to work on days the weather is nice.
SE Michigan SN95 Urambo Tauro New Member Area 12 12-17-2016 04:30 PM
**New from NAT!2015 Ford Mustang MRT Rear Window Louvers**Free Shipping! NorthAmericanTuning The New S550 2015-2016 Mustang 3 03-18-2016 12:21 PM
Replacing Fuel Fill Grommet vbonina V6 (1994-2004) Mustangs 6 08-11-2015 03:51 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
Can you replace a plastic window with glass in 2010 GT Convertible? Mustang Sally72 2010-current S197 Appearance Section 10 08-11-2015 08:54 AM
