Runs 3 mins--dies--hard to start
Old 08-07-2014, 07:35 PM
1990 7-UP
1990 7-UP's Avatar
Angry Runs 3 mins--dies--hard to start
1990 5.0 7UP, been sitting over a year. Replaced fuel pump and fresh fuel, fires up when cold, runs 3-5 mins, starts stumbling and dies,fuel pump reland and WOT relays clicking, rapidly, NEW TFI, then found dead EEC relay...replaced. Same Problem. WON'T pull codes. Is the STO supposed to have batt voltage when key is off?? Goes off when turn on Key. Ran wiring harness, found no problems, have voltages at EEC per info I can find. Even opened up EEC looking for bad capacitors. Didn't look like any leakage, although board looks like overheated on section where you would add a piggyback. Have spark at plugs and 35psi when problem happens. Seems to be all electrical problem..........anyone have any ideas?? Been running on this for over a month!!!
1990 7-UP is offline
Old 08-08-2014, 08:55 AM
88 orangepeel notch
88 orangepeel notch's Avatar
That sounds Ilike the same symptoms my car had a couple years ago. It turned out to be a bad ECM. Bought a reman. from AutoZone for $99, ran perfect after that. Just for giggles, make sure your grounds are good and clean.
88 orangepeel notch is offline
Old 08-12-2014, 07:41 PM
1990 7-UP
1990 7-UP's Avatar
Orange Peel-- major problem was INDEED the eec. A bad eec relay going bad had fried the eec. Ran quite well considering it's been sitting so long, even with a new fuel pump and fresh fuel. At least now the MIL comes on, pulled a code 54 on it. Gotta' do a little more work.
djbigskrilla
09-20-2022 01:04 AM
bryan616fl
01-25-2019 09:07 PM
jjwinel78
08-17-2015 03:34 PM
89blueslug
08-10-2015 07:20 AM
Pain.
08-07-2015 10:48 PM
Quick Reply: Runs 3 mins--dies--hard to start
