what is the coating on the valve covers?
Old 08-12-2014, 07:10 PM
9550's Avatar
Default what is the coating on the valve covers?
95 gt, stock valve covers
the 'paint' or whatever it is on the covers was starting to rust through. the coating wasnt rusting, but it was failing and there was some rust underneath.
anyway, i stripped most of it off and used a wire wheel where i could. whatever the coating is they put on there from the factory was pretty tough. i mean, it wouldnt come right off with the wire wheel, i would have to make more than a couple passes and also put some pressure on it.
so, i wonder, this cant be regular old paint?
i have both covers stripped and media blasted and want to paint them, but im wondering if i should use some special stuff, or can i just use high temp primer and high temp paint (spray cans)?
high temp might not even be necessary, but i imagine it couldnt hurt.
thanks in advance for any info on this
9550 is offline
Old 08-13-2014, 08:27 AM
jz78817
jz78817's Avatar
it's either powder coating or e-coat.
jz78817 is offline
Old 08-17-2014, 08:17 AM
64bit
64bit's Avatar
E-coat.
64bit is offline
Old 08-18-2014, 04:47 PM
9550's Avatar
Thanks guys.
I'm working on painting them now.check my post in detailing forum
9550 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
winner99
10-01-2015 01:06 PM
10-01-2015 09:29 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: what is the coating on the valve covers?
