NEED HELP WITH ADJUSTABLE CLUTCH CABLE
Old 08-19-2014, 08:48 PM
schecterplayer
schecterplayer's Avatar
Default NEED HELP WITH ADJUSTABLE CLUTCH CABLE
hi i recently installed the sr performance clutch adjuster kit and am having alot of issues with the cable. it seems to stretch a good bit in about a weeks time. at first the pedal had a lot of free movement. like it wasnt even touching the cable, so i adjusted at the firewall adjuster to take out the slack. fixed the issue for about a week then it came back. i keep reading that the adjuster is supposed to adjust where the clutch engages but for me its only fixing the complete free play in the pedal. i just dont seem to get the concept of how the firewall adjuster can adjust the clutch engagement point. did i install it correctly? i ran the cable correctly and had the firewall adjuster all the way in to begin then made the cable taught at the fork. i then had a little bit of free play at the firewall so i ran it out to meet the cable and the slack was gone. i just dont see how thats adjusting the engagment point. plus the slack always comes back. any help would be great.
schecterplayer is offline
Old 08-20-2014, 06:45 AM
dawson1112
dawson1112's Avatar
I have to ask this , but are you using the stock quadrant?
dawson1112 is offline
Old 08-20-2014, 07:09 AM
StalkerGT
StalkerGT's Avatar
If the stock quadrant is still in you have to use an aftermarket aluminum one with an adjustable cable. They are very easy to swap out
StalkerGT is offline
Old 08-20-2014, 10:06 AM
camaroeater
camaroeater's Avatar
Exactly what i was thinking. Also, by having the adjuster screwed all the way in will create slack in the cable. Your clutch should grab when the clutch pedal is about 1-3 inches off the floor board for proper engagement.
camaroeater is offline
Old 08-21-2014, 06:07 AM
schecterplayer
Lol of course I'm using the Sr performance quadrant
Old 08-26-2014, 04:25 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Cant speak on your setup but usually as the clutch wears the cable gets tighter and you have to loosen the firewall adjuster. Be sure its not too tight and killing your clutch. You should have about a 1/8" gap between the cable and adjuster if you pull the cable forward.
Boss_Hotrod is offline
Thunderball
15
11-22-2015 11:49 PM
kevsgt
10-09-2015 10:12 PM
breaking
10-02-2015 01:27 PM
winner99
09-30-2015 07:04 PM
junior04
09-28-2015 10:53 AM
Quick Reply: NEED HELP WITH ADJUSTABLE CLUTCH CABLE
