mustang steering problem please help
1993 mustang 5.0
caster camber plates
lowering springs
some other things im not sure of
car runs good but it has a steering problem
itll turn left about 2 times but when i try to turn it right it will only go around about 1 time then it stops
is the alignment off?
does it need a new rack and pinion set up?
tie rods?
control arms?
also it was used as a drift car before, but itll be a street car soon
i need the car driveable by the weekend so any help is appreciated!!
lowering springs
tie rods?
control arms?
Your best bet is take column loose at rag joint it will be easier to come apart then trying to get it off of spline on rack. Align the rack side of rag joint which has a flat side so pinch bolt will slide thru. That should bring it back to stock rotation.
SANDY21
08-17-2015 02:41 PM
KEM Motorworks
08-14-2015 10:13 PM
