RESEARCHED and RESEARCHED.. Cannot fix my 95GT - MustangForums.com
Old 09-02-2014, 06:27 PM   #1
tbk1981
tbk1981's Avatar
Default RESEARCHED and RESEARCHED.. Cannot fix my 95GT
Ok... My first post on this site. I understand that there are other threads that may or may not say what I am experiencing. I have researched all of the related threads I could find, tried what was suggested and STILL not fixed.
Car was fine until one day I drove to help a friend with a car. Went to leave and basically the car wouldn't stay running or anything. Backfiring through intake, rough idle and the sound of the car has changed 100%. Since this happened I have replaced the IAC, TPS, PCV valve, plugs, distributor cap and cleaned the MAF sensor. Now, it will idle (fair), but when I just went to drive it, it constantly jerks, kicks and hesitates HORRIBLY. On my way home, which it barely made it back, I literally had to push it up my driveway because NOW it wont even start back up again...
I don't know what else to do at this point!
tbk1981 is offline   Reply With Quote
Old 09-02-2014, 06:35 PM   #2
dawson1112
3 things come to mind right off the top of my head.
EGR stuck open
TFI is going south (thick film insulator ) or other wise the ignition module. Located on the passanger side fender under the air intake
or The PIP ( Profile ignition pickup ) located inside the distributor.
dawson1112 is offline   Reply With Quote
2014 convertible water drains jerrytubes 2005-2014 Mustangs 2 10-23-2015 12:11 PM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 04:55 AM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 01:02 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 05:26 PM
Hello All RCS02v6 New Member Area 4 09-29-2015 01:46 PM
