AOD experts (gear selection)
Old 09-29-2014, 01:55 PM
88 orangepeel notch
88 orangepeel notch's Avatar
OH YEAH !!! Since you asked lol.
Best time with the AOD was a 13.5 @ 108, high 2.1 60ft was normal on street tires. It didn't have a traction problem out of the hole as my cam didn't start working till 3000 rpm, and my stall flashed at 2700/2800. 4:10s would have been perfect for my setup, but I swapped to a T5 instead and couldn't be happier with that decision. It knocked over a full second off my time, I can 60ft in 1.7 without trying hard (on slicks), freed up 25hp at the wheels.
I really like my set up now with the 3:55s / T5, but would have gone 4:10 if I kept the AOD.
88 orangepeel notch is offline
Old 09-29-2014, 01:58 PM
Cali_Screw
Cali_Screw's Avatar
Why do you think the difference would be in 1/4 mile time between 3.73 vs 4.10s if it was perfect world run?
Cali_Screw is offline
Old 09-29-2014, 02:05 PM
88 orangepeel notch
Maybe a tenth or two at most. That first 60 feet is everything.
Old 09-29-2014, 02:44 PM
Cali_Screw
Cali_Screw's Avatar
If I ever run nitrous or boost the 4.10s is going to make me run out of gear wont it?
Old 09-29-2014, 03:07 PM
88 orangepeel notch
That's possible when you start climbing the horsepower ladder. Maybe someone who runs 4:10s will chime in here and see what he's going thru the traps at. But with 3:55s and the manual, I'm short shifting to 4th at maybe 200 ft before crossing the line, other wise I'm hitting the limiter in 3rd just before. I don't think you'll run all of 4th in a 1/4 mile. But I really don't know.
EDIT: I forgot your AOD, that might be a problem as it won't shift into OD at full throttle. Not that you'd want to do that on a stock AOD anyways.
Old 10-10-2014, 02:16 AM
84CopperGT
84CopperGT's Avatar
I had 3.73s on my 84. Good on the highway, way better than stock. planning for a set of 3.55s on the 89 though due to the amount of highway driving I do.
84CopperGT is offline
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: AOD experts (gear selection)
