Search
Go Back   MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Sign in using an external account
Register Forgot Password?
Search
Sponsored by Weld Racing
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-14-2014, 06:10 PM   #1
drama63
drama63's Avatar
Vehicle: 1994 Ford Mustang Gt
Default Irritating surging/loss of power
So my car is a 94 gt with newly replaced fuel pump and filter, fpr, ignition coil, distributor, plugs and wires. I have checked my tps and the voltage sits at .96. I am using a digital multimeter so i am unable to tell if the transition is smooth but i could not seem to find any "dead spots"
So heres the issue: Once the car warms up it begins to studder/hesitate (whatever you choose to call it) whenever i am cruising and just maintaining my speed with very light throttle(maybe 10%) but once i give it a little more gas it comes to life. it is not throwing any codes whatsoever. I have searched and searched. I would just like to see if any one else has any suggestions. ANy help is much appreciated
drama63 is offline   Reply With Quote
Old 10-14-2014, 08:04 PM   #2
mjr46
Wal-mart lube/tire tech
mjr46's Avatar
Vehicle: 85 mustang
check for vac leaks, make sure the maf is clean, all wires on tight at plugs and at cap, at dusk lightly mist wires with a spray bottle check for any arcing, if present replace wires, make sure plugs are good and no cracks for arcing to occur in the porcelien
__________________
Quote:
Originally Posted by dudegirl View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-14-2014, 08:15 PM   #3
Genxer
Vehicle: Honda
EGR valve?
Genxer is offline   Reply With Quote
Old 10-14-2014, 08:26 PM   #4
mjr46
mjr46's Avatar
Vehicle: 85 mustang
Quote:
Originally Posted by Genxer View Post
EGR valve?
only if it's partially stuck open or getting vac when it shouldn't, but then again a koer should pick that up as pinle position sensor has learned open and closed voltage positions in the KAM
__________________
Old Yesterday, 07:05 PM   #5
drama63
drama63's Avatar
is it possible that oil blowback into the intake could cause this? or possibly the pcv being bad or clogged?
MustangForums
Ford Mustang
Paid Advertisement
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Emails Backup
