AOD Upgrade
AOD Upgrade
It's that time. I wasn't planning on doing one this early in my build but it's inevitable. I need a trans that can be manually shifted with a Hurst ratchet shifter and hold over 950 rwhp. My engine is currently being built by a buddy of mine and it is a 393 stroke big bore Boss 351W with twisted wedge 225 heads, a turbo cam and trick flow manifold with 90MM Accufab TB. It will be getting, at some point, a Garrett GTX4202R turbo with 5 inch downpipe to twin 3 inch tailpipes. But that's nothing without a transmission that can't handle it. Anyone know a good place that wont charge $8000 for a transmission? I've got about $5000 right now.
Although a 6 speed auto would be nice it's based off a GM product and costs $8300. Also, I haven't seen a single review on them.
http://www.tciauto.com/tc/6x-six-spe...le-shifterhtml
EDIT: Took a ride in my buddies 347 Vortech 5.0 and have decided to go with a Vortech V3. Nobody makes a single turbo kit for a 351W Fox that will fit the turbo I would use and I don't really want to build another turbo system and have the car in downtime for 4-6 months in my garage/chickencoop.
....rollerized c4 better option but no overdrive, lentech offers a good aod strip termintator good to 1500 hp but overdrive is limited to 550 ft lbs
http://lentechautomatics.com/products/
I'd go with a chevy power glide if your getting close to 1000WHP. My builder has told me My C4 is good for big power but I don't plan on going much higher than 800. Lentech is the best bet if yor going to want OD. A daily driver???.
yeah. I'm going to have a few tunes. one will be low boost for street and the other will be for the open track, I don't drag race, I like the turns.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
