1989 mustang 5.0
Old 11-22-2014, 06:23 PM
harley guy
harley guy's Avatar
Default 1989 mustang 5.0
i have a 89 5.0 and i just got aluminum heads and a trickflow stage one cam can i use the same stock push rods ?
harley guy is offline
Old 11-22-2014, 06:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you must measure...no way around it
mjr46 is offline
Old 11-22-2014, 06:36 PM
harley guy
harley guy's Avatar
yeah i thought so i need to get some rocker studs to and guide plates not sure on the guide plates 3/8 flat or 5/16 raised any ideas lol i am a new ford owner so this is all foreign to me
Old 11-22-2014, 09:15 PM
bluebeastsrt
bluebeastsrt's Avatar
What kind of heads? Different heads use different rocker studs.
bluebeastsrt is offline
Old 11-22-2014, 11:31 PM
harley guy
harley guy's Avatar
they are pro comp aluminum 2.02,s the place i got them have the other parts for them but i like to buy from late model resto
Old 11-23-2014, 12:02 AM
bluebeastsrt
Ahhh good ole pro comps. 3/8Th. For those heads.
Old 11-23-2014, 11:23 AM
harley guy
harley guy's Avatar
cool thanks fgor the help lone more question lol so 3/8,s guides with the 7/16ths screw in studs with 3/8ths rod for the rockers can i use any roller rockers that take a 3/8ths stud mount
Old 11-23-2014, 12:42 PM
bluebeastsrt
Sure most aftermarket roller rockers will work.
Old 11-23-2014, 07:52 PM
mjr46
mjr46's Avatar
yes but get a decent set such as comp gold series
mjr46 is offline
Old 11-23-2014, 10:06 PM
tinman
tinman's Avatar
I would check those heads and make sure which stud size you need, 3/8 or 7/16.
Then get the guide plates.
Borrow a rocker in the ratio you are going to use, 1.6 are stock, 1.7 were O.E. to some Cobra types.
Get an adjustable push and a set of 12" calipers and find out just what you need for a pushrod.
BTW, check the valve/piston clearance before you fire this thing up.....
tinman is offline
MusBBad95
08-17-2015 09:39 PM
Soldier GT
08-12-2015 03:46 PM
05slpGT
08-12-2015 02:32 PM
daytooday
08-11-2015 09:22 AM
cema93
08-10-2015 09:35 PM
Quick Reply: 1989 mustang 5.0
