My pony will not start
Ok, just added bolt on too my 5.0.... All new B303 cam, double timing chain, distributor, spark plugs, blaster cool, dual electric fan,pulleys, roller rocker-arms-rods, gt40x heads, trick flow upper lower manifold, alternator, all gaskets, starter, starter solenoid, etc still will won't start! My buddy said I should buy starter shems but I can't find anyone who sell them, any ideas!!!!!!??????
A) This Thread Should Be Moved Over to Technical Discussions.
B) More Info Would Be Useful. Does Motor Turn Over? If Not Is There Power To Dash and Acessories, And Do Headlights Dim When You Try To Turn the Key To Crank It Over. If It Does Turn Over Is There Spark? Fuel Pressure? Do You Have A Code Reader for OBDII Codes?
11-10-2015 11:39 AM
10-05-2015 06:07 PM
