Help vacuum leak
Old 12-20-2014, 06:36 PM
tm8004
tm8004's Avatar
Default Help vacuum leak
So I've wondered and wondered what's been wrong with this mustang I bought. It's a 94 5.0 always wanted one bought it cheap expecting to fix it but I'm stumped. So it's had a bad idle ever since I got started replacing the usual like the maf and iac so recently I was gonna replac the intake manifold gasket and realized a hose that goes under it is missing. So there the leak and so when I look up the hose it's the one that goes to the canp but there's already one connected to it. So I'm asking if anybody has a good diagram with pics I'm pretty new at this or could someone help me figure out what these dudes before me did
tm8004 is offline
Old 12-20-2014, 06:46 PM
dawson1112
dawson1112's Avatar
Plug it.
dawson1112 is offline
Old 12-20-2014, 06:48 PM
tm8004
tm8004's Avatar
Doesn't fix my idle issue
tm8004 is offline
Old 12-20-2014, 07:01 PM
dawson1112
dawson1112's Avatar
Then you have something else other than a vacuum leak that is causing it.
Have you ran the KOEO/KOER tests to check for codes?
I would start there first before spending any more time or money.
Old 12-21-2014, 05:43 AM
Michael Plummer
Michael Plummer's Avatar
Vacuum leaks can be difficult to locate on your own. Look for a performance shop, Automotive Dealership, or service station that has the ability to perform a smoke test. The smoke test will take out all the guess work by locating your leaks and that would be a great starting place.
Once all vacuum leaks are replaced, I would run the following tests, KOEO, KOER, cylinder balance test, etc. http://www.muscularmustangs.com/test1.php
At this time it would be a great idea to perform a full tune-up (oil, transmission, rear diff. fluid change, spark plugs, spark plug wires, cap and rotor, fuel filter, and any other parts/sensors that may need replacing. Make sure you replace sensors with OEM ones, the quality is 10x better.
Michael Plummer is offline
Old 12-22-2014, 09:03 AM
leftyatm
leftyatm's Avatar
Check out Scotty Kilmer on YouTube he shows how to do a smoke rest using a cigar and when he is done he enjoys the rest of his cigar.
leftyatm is offline
Old 01-02-2015, 09:42 PM
tm8004
tm8004's Avatar
It's not just a vacuum leak it's the actual hoses not connected to the right place I see other car pics and diagrams and the pcv valve hose is supposed to go under the intake manifold but then there is a hose missing so I need a description of where the hoses go
tm8004 is offline
Old 01-04-2015, 10:56 AM
eb2gt
eb2gt's Avatar
look on the corral, I believe there is a diagram on there.
eb2gt is offline
Old 01-11-2015, 08:17 PM
arnie93lx
arnie93lx's Avatar
Link below is to the vacuum diagram
http://www.allfordmustangs.com/forum...e-routing.html
arnie93lx is offline
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Help vacuum leak
