C90E Heads????
Old 01-20-2015, 03:11 PM
mikesr4565
mikesr4565's Avatar
Default C90E Heads????
I am looking to pick up a set of pre smog heads for my Fox. The casting is C90E, with 302 stamped inside by the rockers. I have tried researching and what I find is that they are 1969 351W heads. It don't make since to me because they say 302 by the rockers. Can someone help me out?? Also will this be a better head then what my 87 Fox came with??
Thank you
mikesr4565 is offline
Old 01-20-2015, 06:47 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
not much of a better head......gain is marginal.......gt-40/gt-40p would better suit you
mjr46 is offline
Old 01-20-2015, 08:21 PM
mikesr4565
mikesr4565's Avatar
thank you, i was told gt40p heads were a good upgrade, just waying my options before i tackle the job
Old 01-21-2015, 01:41 AM
barnett468
barnett468's Avatar
1969 302 closed chamber 58 – 60 cc’s, 1.78 in valve, 1.45 ex valve . .. same as D00E-B heads.
They are not an improvement.
if you run a higher performance with the gt heads, i would get new springs and mil them to around 58 cc's if you run premium gas . . alexes parts sells the springs.
barnett468 is offline
Old 01-21-2015, 04:35 AM
bluebeastsrt
bluebeastsrt's Avatar
Just curious but what's your budget OP? You'd probably be better served picking up a used set of performance aluminum heads off of eBay or Craig's list. I know it tuff going faster on a tight budget.
bluebeastsrt is offline
Old 01-21-2015, 02:17 PM
mikesr4565
mikesr4565's Avatar
yes its kind of a tight budget. I do shop craigslist a lot. When I find something I come here to you guys and get direction on which way to go.
Thank you
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: C90E Heads????
