Idle problem
Old 04-22-2003, 03:16 PM
crashgoins
crashgoins's Avatar
Default Idle problem
I have a 91 GT converible,When I'm driving in any gear at about 2500-3000 rpms and I let off the gas it stays at 2500 rpms and won't go down. Stop the car rev it up and it still won't go down. Pop hood, unplug the idle control valve and it idles great. Can anyone help!!
Thanks
crashgoins is offline
Old 04-22-2003, 03:30 PM
spike306
spike306's Avatar
check your throttle linkage, sometimes they break and can cause it stick like that
spike306 is offline
Old 04-22-2003, 07:54 PM
crashgoins
crashgoins's Avatar
Could be the thottle linkage! When the car is reving up I can turn it off and then turn it back on and it dosen't do it anymore. Does turning off reset something?
Thanks
Old 04-22-2003, 08:14 PM
spike306
spike306's Avatar
try this before you do anything, clean out the throttle body assembly. it gets a lot of build up that can cause your idle to do wierd things. take off the cold air tubing, and reach into where the butterfly is, and cleand out all that crud
spike306 is offline
Old 04-22-2003, 08:55 PM
crashgoins
crashgoins's Avatar
Thanks, I will try that tomorrow , again thanks I hope that is all it is!!!!!
Old 04-23-2003, 11:39 PM
crashgoins
crashgoins's Avatar
Looked at throttle linkage, check, cleaned throttle body and idle air control valve, check, guy at parts store said it could be the map sensor, any thoughts, thanks
Old 04-24-2003, 06:46 PM
spike306
spike306's Avatar
chek map sensor and throttle positioning sensor
spike306 is offline
Old 04-25-2003, 12:19 PM
crashgoins
crashgoins's Avatar
It was the map sensor, changed yesterday and all is
well!!! Thanks for all your help spike306!!
Old 04-26-2003, 07:06 PM
spike306
spike306's Avatar
that's awsome, glad to hear that your back representing the stang nation
spike306 is offline
Old 08-10-2003, 06:36 PM
stalker92
stalker92's Avatar
(Spike306) My idle is sticking at 1500 for a couple seconds then drops to 1000 for a couple seconds then drops to normal sometimes, but mostly doesnt come down. I cant seem to find the problem, the ecu and idle motor arent that old, tell u the truth i have no idea wats wrong, id appreciate if u could help. thanx
stalker92 is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Idle problem
