answers for shimmys in my car
A few quesions actually,
1. Ive heard that the pistons in the 92-95 GTs were made cheap in the 302s. However, i do have an older rebuilt 302 from an 84Thunderbird. and the 302 engine running in my 94GT i have now has over 150K miles on it : and definately some where theres a vacume leak. It should be simple to do a 302 bottom end swap right?
2 My starts to shake every other other split second after 35mph. Feels like the car is tapping on the breaks and you can feel a sudden slow down and a bump vibration through out the entire car.
What is that by the way, it feels like its the tranny but i know its not. it bangs itself up and theres no fuel getting in it seems. And i know it could be a number of problems. Im sure some of you have had this same problem and know the answer. Please help.
<edited><editID>Syndicate</editID><editDate>37978.6516550926</editDate></edited>
actually its not a vibration its more of a bump.. i drive for 3 more seconds then bump. drive more for a few seconds then bump bump. and it slows down a little bit each time<edited><editID>Syndicate</editID><editDate>37978.65</editDate></edited>
is your fuel pressure good??? injectors good??maybe O2 sensor?? or TPS sensor?? does it feel like TCS??? brake rotor?? all i can think of. is it AOD?? <IMG src=smileys/smiley5.gif border="0">
I belive that the later model 5.0s actually had forged pistons but im not 100% sure.If they are forged they will hold up to about anything.Your 84 T-bird motor im almost positive has cast pistons.</P>
</P>
Both have their ups and downs.</P>
Originally Posted by TheGmKiller331
Brakes are the first thing that comes to mind.Check and make sure your brakes arent binding or warped.Also check your motor and tranny mounts.
yea, wat he said. </P>
Is it almost like a slight hesitation? What comes to mind is that wth that much mileage, there could be a significant amount of slack in the timing chain causing the cam and distributor to do wierd things. I had an '87 Ranger 2.0 1BBL carb, and did what you described. Bump, and jerk, then clear up until under a good load(gutless anyway<IMG src=smileys/smiley2.gif border="0">), then the distirbutor went out.
