engine swap
Old 03-31-2015, 04:31 PM
smokn88
smokn88's Avatar
Default engine swap
working on a 88 gt. taking out the 5.0 and replacing it with a 347 stroker. looking for some insights of what can go?, what has too stay as far as wiring ?. and fuel lines?
smokn88 is offline
Old 03-31-2015, 04:33 PM
smokn88
smokn88's Avatar
I am going from efi to carburated
smokn88 is offline
Old 04-01-2015, 05:47 AM
bluebeastsrt
bluebeastsrt's Avatar
Everything can go if your going carb as far as the main harness under the hood and injector harness. You'll need to lower fuel pressure so you'll either need to run a new low pressure pump and new fuel lines. ( correct solution ) or try to regulate your current high pressure pump down to about 6 pounds. Do a little research. There is a ton of info out there on the EFI to carb subject.
bluebeastsrt is offline
Old 04-02-2015, 08:03 PM
smokn88
smokn88's Avatar
thank you for the response this car is gonna way cool, and way fast if not there is always the blower option and nos
smokn88 is offline
Granatelli Sales
01-20-2020 12:34 AM
Nick Oliver
10-17-2018 04:22 AM
97SN95GT
09-13-2015 09:45 PM
mdj89
09-06-2015 11:08 PM
zachary1988
09-04-2015 03:04 PM
Quick Reply: engine swap
