Door Locks
Old 04-05-2015, 09:00 AM
ponyboy302
ponyboy302's Avatar
Default Door Locks
Hey guys. Im having a problem with my door locks suddenly.
When I push the button they will lock but when I press to unlock nothing happenes.
The guy at the auto store told me the lighter and locks are on the same fuse but I looked in the chiltons manual and it seems they are not. My lighter has also stopped working though.
Any ideas?
ponyboy302 is offline
Old 04-05-2015, 01:15 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
try the passanger side will it unlock and lock ??
mjr46 is offline
Old 04-05-2015, 01:18 PM
mjr46
mjr46's Avatar
lol at parts store know nothing..........easy to poke a hole in his rationale....even if they were on the same circuit.........it would not allow locks to work at all, since they lock.....= could not be a fuse on that circuit if both ran off it...both circuits would not work at all.
mjr46 is offline
Old 04-05-2015, 02:23 PM
bluebeastsrt
bluebeastsrt's Avatar
The fact something happens when you push the button rules out the fuse. Your automatic lock actuator or the switch itself is most likely shot and needs replacing. Should be a fairly cheap fix. Just don't destroy your door panel if you take it off. Harbor freight sells an interior trim removal kit for 7 bucks.
bluebeastsrt is offline
Old 04-05-2015, 04:05 PM
ponyboy302
ponyboy302's Avatar
It is the same on both sides,the lock is working but the unlock is not.
Old 04-05-2015, 06:14 PM
bluebeastsrt
If it's doing the same thing on the passenger side as the driver side. Its the switch. If it's only doing it on one side. It's the actuator.
Old 04-27-2015, 09:02 AM
ponyboy302
ponyboy302's Avatar
Is it only 1 switch then that controls both locks or do I need 2 switches, one for each side?
If 2 is it common for them both to go bad at the same time?
Old 03-04-2016, 09:51 AM
ponyboy302
ponyboy302's Avatar
Sorry to bump this old thread but I have not yet fixed the issue and I am sure if I need 2 parts or just 1 part.
On each door the lock works but the unlock does not work.
Also the lock/unlock on driver side no longer also controls the passenger side.
Can someone tell me if it is switch or actuator and if I need 1 for each side or just 1 part total....
Also now I have a new issue. The thermostat **** has always been hard to turn. Well now it just turns freely and I can not control the thermostat. Can someone tell me what I need to fix this?
Thanks guys!
Old 03-04-2016, 10:09 AM
ponyboy302
ponyboy302's Avatar
I meant to say i am *not* sure. idk why I cant edit post sorry
jerrytubes
10-23-2015 12:11 PM
guitarman376
09-30-2015 05:54 PM
Sixer4Life
09-29-2015 07:03 PM
09-25-2015 06:58 PM
Quick Reply: Door Locks
