header gaskets for bbk
Old 04-14-2015, 10:18 PM
canamwrecker
canamwrecker's Avatar
Default header gaskets for bbk
I have some long tube bbk headers and after finding out there's no hole in the header I found out there's no gaskets.. if I have bbk what kinda gaskets can i use?
canamwrecker is offline
Old 04-14-2015, 10:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
FEL PRO 1415
mjr46 is offline
Old 04-14-2015, 10:29 PM
canamwrecker
Thanks any idea where I can get them.. like orileys or somthing
Old 04-14-2015, 10:47 PM
mjr46
mjr46's Avatar
summit racing or a speed shop, or any parts store that carries a line of fel pro's performance gaskets.........our local pep boys carries such as well as my local speed shop
mjr46 is offline
Old 05-06-2015, 02:45 PM
chillboy96
chillboy96's Avatar
No gasket for the headers or no gasket for the flange end of the headers?
i have bbk longtubes use bbk gaskets you can buy thenm on ebay,from bbk.felpro are some of the worst gaskets try not to use and if its at the flange end they don't use gaskets they just bolt to your bbk x or h pipe.
chillboy96 is offline
Old 05-06-2015, 03:59 PM
mjr46
mjr46's Avatar
Originally Posted by chillboy96
.felpro are some of the worst gaskets try not to use .
oh horse crap........I use them everyday of the week.....header gaskets blow out because no one ever goes back and checks the torque as the bolts often loosen up
mjr46 is offline
Old 05-08-2015, 03:18 AM
s6auto
s6auto's Avatar
Default HEADER AND EXHAUST GASKET!!
I have recently cracked a gasket on my 94. having never replace one before I am wondering if I have to replace the bolts when i replace the gasket, or can i just reuse the same bolts.
s6auto is offline
Old 05-08-2015, 03:35 AM
s6auto
s6auto's Avatar
s6auto is offline
Old 05-08-2015, 09:15 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I've reused the old ones, but new ones aren't expensive if you want to go that route. Just temember what mjr said above, always check them as sometimes they do work loose.
88 orangepeel notch is offline
Old 05-08-2015, 06:55 PM
chillboy96
chillboy96's Avatar
you can use the same bolts. aslo go after 25 or so miles recheck them to make sure they didn't come loose and re tight'n the bolts when your car is warm not cold
GimpyHSHS
19
12-19-2023 01:12 PM
Jb145700
08-21-2022 06:37 AM
Dathan
10-05-2015 05:52 AM
junior04
09-28-2015 10:53 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: header gaskets for bbk
