One last problem - Clutch Cable Seems Too Long
Just finished a clutch replacement on my '92 GT. It turns out I have an aftermarket quadrant (aluminum) but no firewall adjustment.
With the old clutch the adjustment on the clutch fork end was about 1/2" of threads left.
Now with the new clutch the adjuster nuts are "bottomed out" (out of threads) and the clutch isn't releasing (not enough travel, cable is too loose).
I guess I need to buy a firewall tension adjuster but why is the old cable too long for the new clutch?
Thanks
Thanks
As the clutch wears it takes up slack in the cable. This is why every so often you need to let some tension out of the cable to avoid the clutch slipping. You could possibly get by for now by adding some washers or a spacer behind cable adjuster on the fork side.
Found the Problem
I removed the cable and found that the clutch cable was trying to come through the fire wall.
Of course it needs to be repaired properly but I can't do the further dis-assembly needed to fix it properly, I'm making some plates to reinforce the firewall. Pictures will follow.
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
