Help please!!!!!!!! 87gt won't start back up after dizzy been moved
Old 05-14-2015, 06:35 PM
87gtpony
87gtpony's Avatar
Default Help please!!!!!!!! 87gt won't start back up after dizzy been moved
87 gt recently got the car going threw it dizzy bolt was lose. So I thought that would been the problem of misfire and it chokes sometimes.. In process in screwing bolt tight the dizzy move and the car ran horrible. So I tried to adjust it back it got worst. Now car won't start. I've crave numerous times drained batt a lil.. Now when I try crank it makes noises like the flywheel or starter bad. I just got new flywheel on it when I first got it a month ago.. It makes real loud grinding noise.. Please help me guys this is my first mustang and I love it..
87gtpony is offline
Old 05-14-2015, 08:25 PM
mongolchuck
mongolchuck's Avatar
Check your timing first. Put it at tdc on number one and line up the marks on the dizzy and the block to set base timing.
mongolchuck is offline
Old 05-14-2015, 09:19 PM
87gtpony
87gtpony's Avatar
Yea I've done that I've seen the mark on dizzy and lined it up at first the #1 on dizzy was on pointing toward driver side but like I said it won't turn over now you think starter went out its making this horrible grinding noise
87gtpony is offline
Old 05-15-2015, 03:53 AM
petrock
petrock's Avatar
Some clarification is needed here. What kind of no start issue is it? Either no crank/no start & crank/no start. If the motor doesn’t crank then that would’t have been caused by the distributer. Put a wrench on the crankshafts center bolt and see if you can manually turn the motor over without any noises. Make sure to disconnect the battery when doing that to make sure it doesn’t unexpectedly turn over on its own and injure you. Good luck...
petrock is offline
Old 05-15-2015, 07:17 AM
88 orangepeel notch
88 orangepeel notch's Avatar
If the MOTOR is not turning over, AND the starter is just grinding away against the flywheel teeth, then yes, replace the starter.
But I'd also do what petrock ( < I got it right this time lol ) said to make sure the motor turns over freely.
Just out of curiosity, has this car always cranked loudly ? Hence, the new flywheel. The chain automotive stores sell a shim for the starter that may help you. My car, when I first got it, sounded horrible when cranking. I installed that starter shim, and now I can almost hear crickets chirping over my starter, 100% better.
88 orangepeel notch is offline
Old 05-22-2015, 09:19 AM
Boss_Hotrod
Boss_Hotrod's Avatar
What kind of dizzy is it? I had an accel one that worked fine on my stock motor. When we put it into my brother's stock motor it didnt. When we tightened the bolt down the shaft would spin so much (do to spiral cut of gears) that it would advance or retard (not sure which) the timing so much that the car ran like crap. Never fully tightened it because of that. Ended up putting a frankenstein Ford dizzy in his and it has ran fine for a while now. When I tried putting that accel dizzy into my Dart block motor it did the same thing. New MSD does not.
Boss_Hotrod is offline
duffman668
08-26-2015 04:46 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Design1795
08-24-2015 04:41 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Help please!!!!!!!! 87gt won't start back up after dizzy been moved
