Head gasket replacement
06-04-2015, 07:49 AM
If you use your new head gasket to check clearances and you have your heads torqued and taken back off. Should you replace your gaskets? Or can you use them, motor has not run with them.
06-04-2015, 10:59 PM
D.R. THE PATHETIC DORK
I always use a used gasket for mock up.......I wouldn't reuse it as it's been crushed once and as cheap as some oem gaskets are it's not worth the hassle if for some reason something doesn't seal
06-06-2015, 11:42 PM
^^^^^^^^^^^^^^^Same thing here^^^^^^^^^^^^^^^^^^
5.0muscle
01-11-2016 01:17 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 04:12 PM
