Piston valve clearance
Old 06-05-2015, 09:15 AM
snikers01
snikers01's Avatar
Default Piston valve clearance
I have J302 heads that I have been running with a b cam since the 90's. Time for a change, pulled motor mild port job on Gt40 intake and heads. Installed Trick flow stage 1 cam straight up an it is hitting the piston. Pistions are wiesco .30 over. same pistons i had with the b cam. Do I need to advance the cam?
snikers01 is offline
Old 06-05-2015, 11:44 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what size valves are in the j302 heads? are these the original alan root j302's or the svo j302's???? some had 2.02's iirc but most were cast with 1.94's.......also is it hitting radial or vertically??
mjr46 is offline
Old 06-05-2015, 01:09 PM
snikers01
snikers01's Avatar
I thought they were 202's they are svo. Hitting the valve relief and edge of relief see photo
Old 06-05-2015, 02:35 PM
mjr46
mjr46's Avatar
how are you checking for ptv?? are you using a converted lifter or solid lifter??........with aftermarket pistons and afr 185 heads I've used way larger cams and not had an issue?? are those pistons for inline valve heads or twisted wedge heads??
mjr46 is offline
Old 06-06-2015, 11:40 PM
tinman
tinman's Avatar
Time to start playing with advance/retard. You should be able to get .100 clearance on both valves. Use the rings that you are going to use in the engine to check with, not light springs. I would use a welded lifter for checking.....
tinman is offline
Old 06-08-2015, 07:25 AM
snikers01
snikers01's Avatar
Note to self don't install cam at 9pm. Put cam in at wrong timing mark. All is good now. thanks for the reply's.
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
EASTIDEE123
09-14-2015 03:52 PM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Quick Reply: Piston valve clearance
