Best performance combo
Old 07-01-2015, 01:09 PM
Arc123
Arc123's Avatar
Default Best performance combo
I have a 83 mustang glx convertible with a 351 police interceptor, ford 9 inch 3.73 posi.
Borg Warner t-5. I feel this car should be burning the tires off, but I doesn't at all, what gear ratio should I have, or what needs to be done. Thank you for your help
Arc123 is offline
Old 07-01-2015, 09:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what does 351 interceptor mean?? where did the motor come from / out of?? those motors are nothing special in stock form
mjr46 is offline
Old 07-02-2015, 11:51 AM
88 orangepeel notch
88 orangepeel notch's Avatar
You mean it won't spin the tires in 1st gear with a T5 and 3:73 rearend ???
And if your serious about looking for advice, we're going to need a lot more info as something is really wrong with your setup.
88 orangepeel notch is offline
Old 07-04-2015, 09:50 AM
bluebeastsrt
bluebeastsrt's Avatar
It's the last of the police interceptors. Haven't any of you guys every seen mad max, the road warrior??? Sounds like a very tired car if it wont spin the tires.
bluebeastsrt is offline
Old 07-10-2015, 08:03 PM
jthorn9
The Godfather
jthorn9's Avatar
You likely have an old tired, and worn drive train assembly. Unless the motor has been recently rebuilt you likely need to look at rebuilding the motor, transmission, and rear end. It will be a bit costly, however, it will help waken up some power. While you're at it, you might as well upgrade the heads and intake assembly to maximize the 351.
jthorn9 is offline
jwog666
12-27-2021 08:09 PM
Dokilar
15
10-16-2015 08:13 PM
ChampInSD
10-02-2015 04:55 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Best performance combo
