Fuel Injectors
Old 07-15-2015, 11:18 AM
red95fiveo
red95fiveo's Avatar
Default Fuel Injectors
I'm new to the forum so this is my first post. I have a question regarding upgrading my fuel injectors and whether or not I should even both with it. I'd like to list what I've done to the car so far and get your advice on what size(if any) to upgrade to. Here's the list of what I've done so far
Edelbrock Performer RPM Upper and Lower intake manifold, 70mm throttle body, CAI, MSD Ignition and distributor, 9mm plug wires, underdrive pulleys, Off road H Pipe w/ flowmasters, short throw shifter, eibach lowering springs.
I know some of those modifications don't matter in terms of fuel injectors but I figured i would list them any way. Please give me your opinions on upgraded injector size or if I should even bother at all with changing them. I don't really plan on doing too much more to the car any time soon. Thanks for your input
red95fiveo is offline
Old 07-15-2015, 11:30 AM
jwog666
jwog666's Avatar
dont bother with the injectors, they will gain you nothing with your current setup, to make use of more fuel, you need more air, without that the pcm will dial back the trim and you will only inject as much fuel as u did with the stock injectors
jwog666 is offline
Old 07-15-2015, 11:39 AM
red95fiveo
red95fiveo's Avatar
Thanks! That's what I needed to hear
Old 07-16-2015, 06:28 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I agree, with your stock heads and exhaust yet, no need for bigger injectors.
88 orangepeel notch is offline
Old 07-16-2015, 02:01 PM
Cosmocrazy
Cosmocrazy's Avatar
Are they the original stock injectors? If so I would have them cleaned if not replace them or have them tested for proper function.
Cosmocrazy is offline
Old 07-16-2015, 02:28 PM
Rob@Evolution
Former Sponsor
Rob@Evolution's Avatar
I'd stay stock but depending on the mileage that's on them I'd replace with same size.
Rob@Evolution is offline
Old 07-19-2015, 03:48 PM
red95fiveo
red95fiveo's Avatar
the car has 46K original miles and it has the stock injectors. I'll probably just leave them be for now. Thanks for the input!
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Injectors
