What's considered normal oil pressure?
Old 08-11-2015, 02:15 PM
yurizx6r
yurizx6r's Avatar
I'm just looking for him to get it down to 1,000. I doubt he'll be able to get it lower with my camshaft. So yours has about 20psi with a 331 stroker at 1,000 idle at hot?
yurizx6r is offline
Old 08-11-2015, 03:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
my 85 is a 347, but that is irrelevant when talking about oil pressure, it is around 23-25 at 900-1000, mine is carbed.........but my 89 is efi and it has a 306 and is the same at 1000 hot idle
mjr46 is offline
Old 08-13-2015, 07:56 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Yeah thats what it shows on my mechanical autometer gauge. Like I say it had me worried at first but then I found that it was okay.
On a different subject, my 1950 8n tractor has about 8 psi at idle. Granted it has a completely different oiling system but it has ran like that for years even after a rebuild.
Boss_Hotrod is offline
Old 08-13-2015, 08:00 AM
yurizx6r
yurizx6r's Avatar
I got it in yesterday, the instructions say to route a wire to the ignition switch. I can do that, but is there an easier spot you guys have done?
yurizx6r is offline
Old 08-13-2015, 11:29 AM
mjr46
mjr46's Avatar
spade tap in the fuse box use a test light to find a switched 12v fuse
mjr46 is offline
Old 08-13-2015, 04:43 PM
Boss_Hotrod
Tap into the red/yellow wire under the dash. I want to say there is one down at the door chime just below the left side of dash next to the center console. You can also pick up a ground there as well as the back light for the gauge. That wire should be brown.
Old 08-13-2015, 08:17 PM
yurizx6r
yurizx6r's Avatar
WTF!? I purchased an auto meter ultra lite oil pressure gauge (4327) and the sending unit does not fit! It has this big fat lip on it that is rubbing against the block and keeping me from screwing it in. WTF!?
yurizx6r is offline
Old 08-13-2015, 10:14 PM
Urambo Tauro
Urambo Tauro's Avatar
Did it not come with adapters?
Urambo Tauro is offline
Old 08-14-2015, 06:19 AM
yurizx6r
yurizx6r's Avatar
The problem is the big lip on the new sending unit. It is rubbing against the block JUST ENOUGH for me to not be able to screw it in. I could sand down the unit, but that sounds like a horrible idea. The pictures do not do it justice, but trust me, it's rubbing. If I had even a 15 degree 1/4 NT adapter fitting, I think it would clear. Damn auto meter.
Also, do to the vibrations, will I be safe with the adapter fittings or should I buy a stainless steel line and relocate it? I just heard a horror story (with a different car) about somebody breaking two of these in their block.
Attached Thumbnails What's considered normal oil pressure?-20150813_215546.jpg   What's considered normal oil pressure?-20150813_215752.jpg
yurizx6r is offline
Old 08-14-2015, 08:02 AM
mjr46
mjr46's Avatar
your problem is, you need to put the oem extension back in place...where did it go??
mjr46 is offline
Quick Reply: What's considered normal oil pressure?
