1994 GT smog pipe removal
Old 09-11-2015, 11:14 PM
wawagner82
wawagner82's Avatar
Default 1994 GT smog pipe removal
I removed my smog pump 10 years ago and plugged the pipe that runs to the back of the engine. The plug finally rotted away and I've got what sounds like an exhaust leak coming from the pipe. Anyone have any luck removing this pipe wiithout pulling the engine? If so, what did you use to fill the port once the pipe was removed?
wawagner82 is offline
Old 09-13-2015, 06:33 AM
64bit
64bit's Avatar
the threads in the head are 5/8-11.
You can pick up a set from a hardware store.
I have several in stock if you're interested.
E-mail me at 64bittuning@gmail.com
64bit is offline
Old 09-13-2015, 09:02 AM
wawagner82
wawagner82's Avatar
Thank you so much. I think I'll run to the local hardware store and see what I can come up with.
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Dathan
10-05-2015 05:52 AM
Teddi
09-29-2015 12:24 PM
09-24-2015 09:18 PM
Quick Reply: 1994 GT smog pipe removal
